Installing Viper 791vx In 99 blazer?
LOL I am in fear for it to! There is a manual and I have the wiring for the vehical. But they have a few wire that I have no idea what they are for. Like the primary harness has a few that I dont know about. like the
Pin H1/1- RED/WHITE (-) 200 mA CHANNEL 2 VALIDITY OUTPUT
Pin H1/7- BLUE (-) MULTIPLEXED INPUT, ZONE 4
Pin H1/9- BLACK/WHITE (-) 200 mA DOMELIGHT SUPERVISION OUTPUT
just bring it to a professional.
i dont think its worth the risk of you trying to do it yourself and risking messing something up rather than just paying 150-300 for someone to install it for you.
and yes you have to start somewhere so whatd Id do is find a professional that knows what there doin and c if hell let you watch or explain how its done while he is doing it. Or help you put it in and explain the proper techniques as he goes along. Dont just go butchering your car
150-300 if you bring it to em?
Yikes!! That's expensive. I paid 380 for a compustar 2w900 installed with a key module and a couple other options.
i dont know the exact figures. i doubt it would reach 300. but its a very rough estimate //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ok got the alarm in and is working but the remote start isint. It will turn over and acts like its going to run but dosent. I have the statuse in put from the bypass too the rear status defoger wire on the alarm. And the ground on the bypass is going to stright ground. Is this right?
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
sparkplug121988
SWINE FREE!!!
sparkplug121988
spokane, wa
sparkplug121988
Brendon Jenness
    May 8, 2024
    May 8, 2024
