Installing Viper 791vx In 99 blazer?
Ok the only wire I see that I can use is the blue/white off the remote start harness for 2nd statuse/ rear defoger. And as for programing the tach I tried what you said and no luck. The led will not light up when pressed while the car is running. ???? I am confused I have check all wires for the by pass. The only wire not being used is the one to the starter relay and bulb check. Do I need those? I have also checked the tach wire and is the right one. So I'm not sure what to do now
you must press the valet switch with like 10 seconds of starting the car
the harness im talking about with be small with 4 wires it will plug into the RS relay pack next to the ribbon harness... It will have a blue, purple, orange, and pink wire. These wires will be no more then for inches long the blue wire is your status wire or you can use the blue wire in the RS ribbon harness which is what i used to do as i never liked to the end look of the mini harness
Ok I changed the status wire to the mini plug with the blue wire. But still nothing its doing the same thing. And it still wont learn the tach. What should I do. I know the connection are good because I was soldering them. And I have doubled checked.
Where did you get your tach?
Your AC voltage should increase with an increase in RPM.
To learn the tach you just start the car press and hold the valet, the led will light up and stay constant when you have done so correctly. Then turn it off.
sparkplug121988
SWINE FREE!!!
sparkplug121988
spokane, wa
sparkplug121988
