Help With Wiring My Subs... 2ohm vs 4ohm? ahhh plz read
Alright, So this is what I have...
I have two Alpine Type-X Pro 12 inch subs (set in a custom built box) and I have two Alpine PDX 1.1000 Amps... (one for each sub)
I'm debating on how to wire the subs... I've had it wired a certain way for a while now, and everything been fin, but recently my amps cut out for some reason... So tonight I was taking everything out, and rewiring to diagnose the problem...
I know my subs have two + and two - on them, I believe that means they are dual channel voice coils? I just don't know the difference between wiring them to 2 ohm, or 4 ohm, or 8 ohm, using parallel or blah blah blah (every time i Google about it it just makes my head hurt)
Someone please shed some light on this for me?? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif So maybe I can also understand a little bit better...
Links to what I have
Two of these...
Alpine Electronics of America, Inc.
Two of these...
This is what the rest of my car has //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...
1 x Alpine Electronics of America, Inc.
2 x Alpine Electronics of America, Inc.
If I understand correctly you are using one sub on each amp?
I don't have any experience with the X series but you need to know what ohm you subs are before you rewire any subwoofer.
Again, I have never used that amp but the specs show it to be stable to 2 ohm.
So as a word of caution - If your subs are dual 4 ohm, attempting to wire both subs on ONE amp in parallel will give you a 1 ohm load. This is what the previous post suggests and that could turn out bad for your amp.
See if this helps any: JL Audio - Car Audio Systems
One dual 4 ohm sub per amp (+ to + / - to - ) will give you a 2 ohm load at each amp - which according to the specs should be safe.
If this is the way they are hooked up may need to check your gains (turn them down some). Looks like those subs could take more power than those amps are putting out. Could be that you to have cranked the gains up a little too much. Speaking from the specs only.
Hope this helps
you must like alpine lol
well 2ohms gives you more power so the more ohms the less RMS,so you monoblocks might have 700w rms at 2ohm but 550w at 4ohm
get it?
2ohms should give you more power but if you look at those amps it's the same output running 2 or 4. either way it's still 1,000watts. so with that said not sure why you took it all apart to begin with. you should have had it running to 1 vc then the jumper running to the other vc. if your amp is cutting out it's not how you wired the subs up. turn your gains down a hair. make sure all of your connections are tight. when does it cut out? just whenever or, when your running it hard for a little while?
The PDX amplifiers provide the same amount of power @ 2 or 4 ohms, so it doesn't matter how he wires the subs.
The real question is how he's going to wire each sub @ either 2 or 4 ohms. It's impossible to have that option. The Type X is only available in 4 ohm or 2 ohm dvc configurations.
- The 4 ohm dvc can only be wired to 2 ohms, because the PDX isn't going to do shit @ 8 ohms.
- The 2 ohm dvc model can only be wired to 4 ohms, because the PDX isn't stable down to 1 ohm.
I don't know what a pair of the PDX amps will do strapped, or if they're even capable of it, so I'm basing what I've said on the OP dedicating each amp to one sub...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
555
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
944
Al Stotz
Al Stotz
Carol Stream, Illinois, United States
misfit138
audiobaun
    May 19, 2024
    May 19, 2024
