Help Building a box.
Creepin92
USA
I have a cerwin vega 104 (model Vega104) 10 In. Sub, I need help building a vented box with the most output. I need help with Cu. ft. and what to tune the box to. I looked on there website and it said 1.60 Cu. Ft. and tunning freq of 35hz, But i dont know if thats a good tunning freq for this ten or should i go a lil higher. I have plenty of room so, box size really dont matter, just want a good sounding box. Here are the Spec of the Sub.
FS: 23Hz
Qts: 0.252
Qms: 6.26
Qes: 0.262
Vas: 1.78 Ft. 3
Xmax: 1.40 (35.6mm)
Revc: 3.2 Ohms
Sensitivity (1w@1m) 92 db
Wrms: 300Watts
Thanks for any help!!
OK i have decided I am goin with a box with a (net volume) of 1.60 tuned to 35 Hz with a slot port, can someone help me with box demensions* and port (W x H X L). Ive been working on this for about two weeks and cant figure it out. Thanks LOL
379
323
Creepin92
Creepin92
USA
paikiah
    May 24, 2024
    May 23, 2024
