Gain Setting Tutorial
okay, My situation is a bit weird. My amp has 2 stages of amplification- it can boost the input signal (like a post-line line driver) and then the usual output gain. The front channels are rated at 75w/ x 2 into 4 ohms, and the sub channel is at 250wrms into 2 ohms (single sub- dual 4ohm VC's) Help!
My amp will be bridged on a 2ohm DVC sub wired down to 1ohm load
If I understand, my calculation should be..
1*400 sqrt=20V ?
I use my DMM to set my gain to 20V?
running off an alpine HU with 4v outs
I have the old school phoenix gold M25 and i dont know how to set the bass or gain. It will be bridged at 2ohms putting out about 140watts i think. This is on my 12" Type-R. There are 2 knobs on the amp, 1 for bass and the other for gain. The gain one says .2-2 for it, where should it be? Also what do i do with my bass knob?
If your sub is clipping can you hear it?
My amp will be bridged on a 2ohm DVC sub wired down to 1ohm loadIf I understand, my calculation should be..
1*400 sqrt=20V ?
yes you are correct on your calculations. make sure everything on your H/U is flat line and LOUD is off. use the correct test tones and make sure your amp has bass boost off.
First, you should consider buying yourself a Digital Multi Meter (DMM).
Next, follow this tutorial:
http://mobile.jlaudio.com/products_amps_pages.php?page_id=30
Re-read many times before attempting so you can learn.
Now, for your amp, the bass i would suggest to set down to zero. Because setting the gains will do the job. You will learn about the gains on that tutorial.
For the bass knob, i have no clue. Never really messed around with one, nor owned one.
I meant 50-60V
Like some guy in the early pages of this thread had like 56.7 volts
-Blake
Basically, your just going with the formula that is provided.
Here's the formula you'll need ...
Sqrt(Power*Resistance) = Voltage
(i.e. If you bridge a 4 ohm subwoofer to your amplifier that is rated to produce 100 RMS @ 4 ohms in bridged mode, you would want Sqrt(4*100) = 20 volts)
Square Root ( RMS of SUB * Ohms You will be using) = The Volts you will need to set gains.
Try and remember where u saw that post about "50v" i will check it out.
Love,
Dante
hi just wondering will it hurt my amp if i run it 250 watts over rms is that a little too much over, i have a power acoustik ov2-1600 and 760 watts rms at 2 ohm 1600 watt max power
SirClay
President
SirClay
Texas
Tek18
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
