my plastic inline fuse holder melted last night and fell apart. Can someone tell me why this happened and if i should just get a new one or if there is something wrong.
So where is this fuse holder located at in the engine compartment or what ?my plastic inline fuse holder melted last night and fell apart. Can someone tell me why this happened and if i should just get a new one or if there is something wrong.
Excuse me but if the power was so much that it made the fuse holder melt then it would have burnt the insulation right off the copper wire and possibly burned the car to the ground. If this fuseholder was not in the engine compartment then there could be a real problem that needs to be fixed. You may have copper exposed and touching metal and shorting out your system.yes get a new fuse holder. The reason it melted is because there is to much power going throught the fuse. which means the fuse is to big. u can an new one from about any car audio store.
Ok, but I was assuming if this wasn't an underhood fuseholder.my brother had 4 aguge power and gound wire. I was lightining audio and he had an 80 fuse in it. B/c he kept blowin fuses and he was goin down the highway and the music quit. He looked under the hood and his fuse holder mellted to the. like i said the fuse is too big.
- holla
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Exactly what I was thinking...... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifIf there was too much power, then something is severely wrong. The fuse holder should be capable of sustaining itself under load at it's largest capacity fuse. If it was above that capacity, the fuse should have blown.My guess, near something hot. In *both* cases.
the wire can still heat up due to an overload, the fuse can handle it but the holder is prob a piece of sh, get a good one there worth it or the problems gonna keep happening. good luck!If there was too much power, then something is severely wrong. The fuse holder should be capable of sustaining itself under load at it's largest capacity fuse. If it was above that capacity, the fuse should have blown.My guess, near something hot. In *both* cases.
Plastic inline fuseholders use a spring to push the contacts against the fuse. If the spring broke, or if you had tension on the wires, the contacts could have been making weak connection and result in high resistance. That'll make heat.
more like full of lulz //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifThe fail in thread is strong... Except for this answer:
It was caused by either a bad connection at or inside the fuse holder.. a bad connection means an area of high resistance, and that will generate heat.. enough heat to melt the thing...
Anyone who tells you different doesn't have clue what that are talking about.. that is unless you had it sitting on top of you exhaust manifold..
