enclosure help
Sealed is easy. The formula to figure volume is length x width x height / 1728. Keep in mind these are INTERNAL measurements. So if your using 3/4" material, you can just measure the outside of the box, and subtract 1 1/2".
that is what i need ,the outside measurements for the wood. Im new at this so if i sound like a newb it is because i am. any help would be appreciated.
Thanks man that would be great. I want to try and start making my own boxes. I am going to try sealed first because i know that would be the easiest for a first timer.
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
BigAl
BigAl
birmingham,al
mlstrass
    May 24, 2024
    May 23, 2024
