Dodge Ram: 3 MJ-18's, 14 cubes, ZRS-10
Yes, the box is sitting where the back seats went. As far as length Im not sure...I had quite a few runs and I picked the longest one I had. 10' maybe?
Im currently running a 12" sealed rsd on a center console box with 1,000 watts, Im planning on going a budget SPL system just for comps, something similar to what you are running, because I just need the box and subs...
It is dupli-color bedliner on the box. Right now they are getting 2400 watts(supposedly). I have a battery arriving tomorrow, and as soon as MLA finishes their module for the dodge, the amp will see a true 15.3 volts:)
Doh.. you already said that. I was just looking at the thumbnails and it looked like vinyl. Sorry. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
What kind of battery are you getting? From what I've read recently, batteries like kinetics can only handle 14.3 volts and will fail if exposed to constant higher voltages . Also, I read that Powermaster batteries handle up to 15 volts, but I would still guess that the same thing applies if you exceed 15 volts. Heres a link. : http://www.soundsolutionsaudio.com/forum/index.php?showtopic=17479 If all of this stands true, those devices that up the voltage are trouble. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I have a YT up front and a batcap in back. If the batcap cant handle the voltage, it's gone and Ill pick up some more YT's or something that can, because I know the YT's actually benefit from the higher voltage.
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
961
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
avs20
avs20
Frisco, TX
avs20
    May 16, 2024
    May 16, 2024
