Dodge Ram: 3 MJ-18's, 14 cubes, ZRS-10
Cant wait to see it finished. Im in the process of walling off 2 MJ-18's in my 97 mustang.
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Nice....//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I remember making stangs real loud when I used to install..
Well, it's done minus the bracing that I will do tomorrow.
Lines drawn for subs:
Cutting sub holes:
Everything rounded, sanded and filled:
Bedliner:
If you notice in that last pic, towards the middle of the box it looks like there is a slight bend. There is. When rounding the edges my router bit's bearing decided to fly apart in peices leaving the router digging into the back wall. I was EXTREMELY pissed because everything was glued, nailed, and dry. Tearing the back wall off would have ruined the box. So I had to improvise. The box is 1/4" lower towards the center, but at least I was able to save the box.
Ill be back with more updates!
14 cubes for (3) 18's? Wow. Of course Meade only has around 5 cubes per 18 so I guess you are right in line.
Mach 5 recommends 4.5 cubes ported for the MJ18.
OP,The box looks good! That should WANG in that truck! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif The MJ's are nice subs... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
How many watts are you going to be running?
I will probably run ~800 to each sub. Thanks for the comments guys. Im about to go brace the box and it will be finished. Now I just have to order the subs!
Just ordered 3 MJ-18's!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Im actually going to be running a different amp with more power than the ZRS-10, so it will be up for sale soon!
Subs just arrived at my door! Amp came yesterday. I might finish up today but more than likely tomorrow since my wife is having a bday party for her friend.
I decided to switch amps, no more ZRS-10! Bring on the watts...HK802SX
avs20
avs20
Frisco, TX
avs20
