Dediated sub for 15-30hz?
silenkiller
Looking for a single sub that will be dedicated to 15-35ish hz. I want to be able to feel the low end in the chest. Any suggestions? Would be running with either (2) 13 W6V2's or (1) 13 W7 to catch the 35-85 range.
Reasonable budget, under 600 dollars please lol. Space is kind of an issue, I don't think I can fit a 15 the two 13's back there.
Actually sealed boxes have more output in the really low freqs than vented. A vented box rolls of at between 12 and 18 db per octave below tuning. A sealed box rolls off at less than 12 (depending on alignment) so at some point the two curves cross. Below the crossing point, the sealed box has more output.
I had a too spec sealed box for my current subs, and they had no output on bass i love you
the only way I think this woudl be feasable is to run a PG cyclone from 30Hz down and have it all crossed over real well, other wide just tune in the low 30's and you will feel it in your chest.
and if you had no output on bass I love you your SSF must be on or you cant hear it but go watch your sub when you play it.
silenkiller
silenkiller
zz
dftnz7
ThxOne
    May 13, 2026
