DD9518 and ap3000d build
added more bracing inside the box, glue and and a screw on all 4 ends and a 4 3 inch screws that go outside the box thru the bracing on all 4 walls
box was giving me problems so i built another one. like my last one its 45 inches wide, 19 tall, 20 deep, ported at 33hz but this time i finished painting the inside of the port and did a 45 inthe port corner. cutting the 45 was wat cut my finger. also found out another reason y it wasnt as loud....my trunk latch was broken at the spot welds and cracked the metal so it was up about 2 inches from closing letting tons of air out the back and around the trunk.
pics of damage
i put 2 self tapping scres on the side of it to hold it down
45 in the corner
not really sure why i did that
also it was a lil flexy so i braced the inside and again 3 inch screws through all sides
putting sealant around the sub
how its sitting now
i also put 2 small blocks of wood to hold the box from moving and its working great.
and i FUC KIN hate liquid nails it ***** ass, it didnt hold **** together like wood glue im never using it again, id rather build a box with superglue lol
you should try to use less screws. you are actually weakening the joints. Titebond is the best way to go with wood glue.
i just didnt want the thing to fly apart. and by the port all but one screw wobbled loose making the box thats y its 2 sets on it i countersunk those so more meat of the screw was though it
thats that liquid nails for you, sh itty ass glue never again
the stuff was still moving around after 20 minutes. if it was 20 minutes with wood glue it would be able to support my weight
this
then your glue is weak and not done setting. Screws are only used to hold the panels together long enough for the glue to dry.
this
Its still not going to hold your box together.
this
To sum it up, use less screws, more titebond, no liquid nails.
Yea liquid nails *****. On my boxes I use tite bond 2 sometimes screws most times not, clamps ftw. Box looks ok needs sanding. If u ever in mooresville area hit me up, would like to check it out. I've done quite a few customers builds in charlotte.
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
928
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
995
Bad4health
Hymen Removal Specalist
Bad4health
charlotte, NC
Bad4health
    May 24, 2024
    May 23, 2024
