DD Subs?
How does there series go? The higher numnber the better the sub? And where can you buy them online?
500 series - entry level sub- around $70
1000 series - a bit better than 500, the 8" is //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif, SQL - $100-?
2500 series - comparable to most mainstream subs, SQL - around $200-?
3500 series- better than most mainstream subs, SQL - $370-?
9100 series- hardcore sq sub, SQ - $650-?
9500 series- super sub, SQL - $500-?
9900 series- hardcore spl sub, SPL- around $800
9900z series - crazy super spl only sub with huge a$$ neo magnet, around $5000
(yes i mean five thousand dollars)
you can contact dd directly if you don't have a dealer in your area, factory direct price
Why isn't the 9500 an SQL sub?
SQL setups usually consist of ported enclosures. The enclosure will make it a SQL setup.
tuan
right on, most people assume that the 9500 series is spl only but that's not true... the mentality comes from the fact that most put them in huge ported boxes, in reality they have good sq if put into a "sql" oriented box. look on dd's official forum, theres a sticky about all dd subs and their purpose
http://forum.soundpressure.com/showthread.php?t=47
Here is what the $5000 99z looks like with the big neo magnet...if curious....
I have to throw this out there. The DD 2500s are some of the most under rated subs out there. Go on the soundpressure board ask about them.Even the Aq SD 2.5s great(best IMO) bang for the buck.
343
16
473
641
THXdts
THXdts
Maryland
audioholic
    May 24, 2024
