It's rated as 900 watts @ 2 ohms and the sub is rated for 400 watts rms.
I've heard that a lot of the TC subs are rated conservatively. I don't expect to push all 800 or so watts that the amp would actually put out, but can I expect at least 6-700? Right now I only have about 350 watts pushing it an I know it can take more.
It's a 12" TC-1000 in a 1.4 cu ft sealed box.
Sub specs.
Double stacked 1" tall ferrite magnets
• 150oz motor structure
• 2" diameter, 4-layer aluminum wire voice coil
• xmax of 24mm (one way linear travel)
• Single poly-cotton spider with intergraded woven leads
• Cast aluminum basket with high gloss power coating
• Either single or dual 4Ω aluminum voice coil with four layers of wire
• 400 watts sustained (1000 watts dynamic)
• High quality thermal flexible epoxies to ensure longevity
• Rigid lightweight brushed aluminum cone
• Vented flared pole piece
• Copper shorting ring
• Rubber half roll surround allows for linear travel
• Dressed in a rubber magnet boot and gasket
Sub specs.
