dc level 3's or rockford fosgate T2D412?
The 4s have a higher sensitivity so they'll do more with the power you give them. They also have a soft suspension so they should be able to move with your power pretty well. I think the 4s would be a better choice cause in the end you could feed them about 1.5k each and they'll still handle it fine.
the only thing is that these rnt going in a truck, they are going in my hyundai genesis so if i want it to fit, i need a sealed box. i know the lvl 3's are recommended for both but the level 4's are recommended for ported. will the lvl 4's work well in sealed?
DC subs require little airspace... What your max dimensions? I'm betting you can go ported.
You can put 4`s sealed. Trust me. If you couldn`t, then I am pretty sure Rusty (the guy who made and designed them) would say explicitly not to.
well i did it,and they sounded really bad,it is quite suggested to run them ported if you search around
Yeah, you have to have just the right airspace, and more power to run sealed than ported. With lvl 4`s sealed I would put 1500+ at each of them to get em loud.
ugh, now some people are saying i should get memphis audio power reference 12" subs (15-PR12D4V2) instead of the DC's. what do you guys think?
Hell no. Id do 1 DC Audio Level 4 15" in a 4.5 net cube box ported and tuned at 32Hz. It will be very musical and get very loud for a single woofer on 1500@1.
Factory. 2021 Chevy Silverado custom trailboss
679
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
715
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
620
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
maxmar04
maxmar04
hell
maxmar04
    May 20, 2024
    May 20, 2024
