DC Audio Level 6 18" single enclosure box, design help
Hello can someone help me to design a enclosure for a single DC Audio Level 6 18" going into Integra hatchback
What would you guys recommend, I have build a box enclosure already 6.8 cubic feet, tune at 33 hertz, but I'm not happy with it, the manufacturer recommend 5.5 cube feet , I have the subwoofer facing up, the port facing back,
Just like to get the most of it, daily music,
Please help, thanks in advance
How did you do the port? 6.8 cubes at 33 hertz should hit pretty good on that level 6. What kind of amp? How is it wired up? Just doesn't seem right. This thing should be rattling your teeth.
Make sure you have enough room for the port to breath. Have you contacted Rusty from DC audio via email to hear his opinion yet?
Are you looking for flat response, more lows or louder?
No I haven't contact anybody, I figured i get some help, advice here, but how do I contact him
I have 2 Brutus brx2400.1d linked together at 2 ohms load
My DC Audio Level 6 sub is 1 ohm I wire it at 2 ohms
The port is 4"wide by 16" high by 16.6 long
I'm planning on getting a crecendo bc5500d, it hits hard but not too hard I seen this subs on YouTube videos I think mine is not there, also it sounds like is not hitting lows, I think is the box that I built I'm not happy, that's why I'm asking for support, thanks
Is there someone here that makes enclosure box for this DC Audio Level 6 sub, i would like to make another box with your help, just help me design it, I'll build it if I can't make it work, then I just buy it from somebody here, I don't mind trying, it's a hobby for me and I have fun doing it, so if someone wants to help me design it, I'll appreciate, thanks
That's nice! It looks like top fire is the way to go for these cars, instead of rear fire, would you say? It looks like there's more room that way, cause these cars get smaller torwards the tail. Thanks for posting pics. I have the same car, and am trying to figure out what can be done with the space back there, with the rear seats up.
Use aero ports
Hello can someone help me to design a enclosure for a single DC Audio Level 6 18" going into Integra hatchback What would you guys recommend, I have build a box enclosure already 6.8 cubic feet, tune at 33 hertz, but I'm not happy with it, the manufacturer recommend 5.5 cube feet , I have the subwoofer facing up, the port facing back,
i have the Dc XL 18 M1 and im running it in 5-5.2 cubes net with a single 8" aeroport. Its suprisingly musical in that size of a enclosure. I need to give it more power
you can contact them at (855) 775-3299
or facebook em at https://www.facebook.com/pages/DC-Audio/184739408307595
They would love to see you get it right and post a vid/pics on their facebook of a single level 6 in action..
I'd say your main problem lies with the hifonics amps. If you have it in a smaller enclosure, it'll basically be even weaker then before with less lows.
I just talked to DC Audio tech support, I was told that my box is too big my sub is not performing good because of the box, they recommend to put the sub in 5.5 cube feet, or even 5.0 with a bigger port 6" instead of 4 tune it at 35hz for my preference, I'll build a new box tomorrow, 5.5 cube feet, port 6 inches wide, see how It does, I'm saving money to buy my crecendo bc5500d
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
I had a JL 600 what amp (XD600/1V2) and the JL Audio Remote Level Control Knob (HD-RLC) installed professionally and hooked up to a JL Sealed 10in...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
180
sergioiron
Miami Fl
gckless
    May 31, 2024
    May 24, 2024
