hispls
Your profile says Miami.... Yeah, I expect Chicago is cold. I've built boxes on snowy days too.. cut pieces outside and assemble inside. Not the best, but when you get that itch to build it can't be helped.Done I just tested the new box, it sounds better, 5.5 cube feet, tune at 35hz, my I get more lows and sounds cleaner, Much better, but same power output, my 2 Brutus brx2400.1d, doesn't have the juice to power this monster, I don't think I'm getting 4800 watts out of my amps, they don't get warm, I play music for 1 hour they were cold, like they aren't even working, my volts drops from 14.7.to 14.1at peak, when I had the 2 amps separate, 1was driving 2cvx 15"1000 watts each at 1 ohm load, the other amp was driving a power acoustik mofo 15" 1700 watts at 2 ohm load, and they were drawing more energy, my volts were dropping to 12.7,something is not right, I don't know how to clamp the amps, but I think they are outputting like 2500 watts they supposed the be outputting 4800 watts,
Has anybody linked 2 Brutus brx2400.1d, so I can get some advice,
I'd have really liked to see double wall on the baffle side (flush mount for preference), and some bracing in there. Personally I'd do double layer all around and triple on the top on a 5 cube box.
Is that the same orientation of sub/port in the vehicle? Does it sit different from the last box in relation to hard surfaces?
If it sounds good it is good. Don't worry so much if you aren't pushing your amps to their limits. If you don't even own an SPL meter you likely won't notice the difference of trying to over-work them to "get your money's worth" power out of them.
If you're have a DMM you can take some voltage and current measurements (AT LOW POWER). Most DMM's will only handle current up to 10A or so before opening fuses, so you'll get a 5V tone at a particular frequency then measure current without changing any settings. Do the same at frequencies 20-80hz at 3-5hz increments and you'll have a good idea of the impedance curve. From there you can measure max voltage and use Ohm's law to see what's happening where. This will be time consuming and I wouldn't want to do it in the winter up north.
