Craziest system on stock ALT!!
Largest setup ive used on a stock 90 amp Jeep alternator was during 2006 MECA World finals with one 18" 5200 prototype in my Marble box, two zenon 5kw amps (10kw total) and four Alphacell 180 batteries. I got 2nd place at finals with a 154.7 just doing burps. Of course, before I ran thru the lanes I put the batteries on a charger. I ended up folding the sub inside out too. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
So it can be done, its just not an optimal setup.
In my old 97 Caviler, biggest system I had on stock alt (think it was 95 amps?) was 4 MTX 1501d's, stock batt upfront and 2 g31 yellow tops in the back
In my mountaineer, At one point I had 4 powerbass 3000's and 2 8d batts, then 2 soundstream 6500's off 5 nsb 125's
i ran 2 ia 20.1's and a sundown 100.4 off a stock alt in an 06 silverado. i had a big 3 upgrade, kinetik 1800 under the hood, and batcap 2000 in the back. had alot less voltage drop then i though i would
IMO, either you didn't turn the volume up much or you had a big *** impedance rise. 2 of those amps will **** a lot of current at full tilt.
i know you're not lying. and batts are illegal in AS1 I'm telling!!!! (yes I know u unhook it for the run)
Huh? We only have 1 battery. Here's the install:
well the reason I created this post was to further see if running a 1600watt system on a stock ALT with an extra Kinetik battery in back, and Big 3 would be fine. I think i'll be ok!!!....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thanks everyone, this board is by far the best car audio forum anywhere. almost 60 posts in about 15 hours!
eddie
ew UK..... I thought u meant the deka was the 2nd batt in the trunk (as if to say 1 batt in the rear). so nevermind that. That's a loud AS1 car, what's the record? should be up there. Let me guess... there's areos coming out of the box somewhere
efm80
efm80
las vegas,nv
bigbangtheory
