Correct way to add extra set of tweeters
dross93ranger
I just ordered a set of Powerbass 3XL component speakers, 80w RMS @ 3 Ohms and an APSM-2075
2x75W @ 4 Ohm
2x110W @ 2 Ohm
I will of course be hooking the Powerbass speakers up to their crossover, what should I do to add the set of Crescendo CTS-1 Tweeters? They are 4-Ohm, 60W RMS and I already have them mounted is one reason why I would like to keep them.
Can i just splice into the + and - before the crossover? The tweeters have their own inline crossover.
you should not add the tweeter in before the crossover as that will lower the ohms the amp sees.
I agree with LACRX (first time ever btw) that you do not need 4 tweeters and using the ones you have mounted might be a good thing to try.
You want to remove the cap (crossover) from the tweeter as keeping it will change the Slope and likely the freq of the crossover point leaving you a hole in your freq response.
Thanks for all your help guys, but I have one more question. The Crescendo tweeters are 60w RMS and the Powerbass are 80...considering the power I will be giving them, should the Crescendo be able to handle it alright? I'm thinking so because the power will be split between the woofer and the tweeter.
Edit: Actually the Powerbass are rated at 60 as well so I am good. The tweeters are rated at 60 and the whole component set is rated at 80.
yes you will be fine
tweeters use much less energy than normal drivers so they do not see the same watts as the mid-driver does.
I would guess that you would need to put over 200 watts to the crossover to get over 60 watts to the tweeter.
I really cringe when people plug in random tweeters into a crossover box that was designed for completely different speakers. Just a dumb, dumb idea from SQ stand point IMO. If this has worked for someone, it must have been due to sheer luck.
What could possibly go wrong?
1. The crossover box uses a lower high pass frequency than what the tweeter likes to play. They may result in harsher sound down low.
2. The crossover box does not attenuate enough, resulting in tweeter being too loud and overplaying the mids
3. The crossover box attenuates too much, resulting in tweeter being too quiet and loss of some highs detail.
Either match the tweeter with a crossover box that's meant for it, or use it active setup. Just because you have an extra set of tweeters doesn't mean you need to use them.
don't add the Crescendo to the Powerbass crossover. that will lower the impedance on the load side of the crossover which raises the crossover point. A 2kHz crossover point at 4 ohms turns to 4kHz at 2 ohms.
add the Crescendo tweeters with their own crossover in parallel with the input to the Powerbass crossover. Yes the amp sees a lower impedance load, but 2 ohms for a tweeter load is just fine for almost any amp (and 2 ohm is nominal, actual is higher).
do you need a second set? only if your first set is improperly placed. put your one pair of tweeters in the right spots, and you have no need for more.
I still don't see an issue with swapping them. I'm not ignoring advice, just trying to learn. The Crescendo are 12 db crossovers and sensitivity is 92dm w/m. Powerbass is 12db and 92 w/m. I like the size and look of the crescendos now and the sound. And they seem almost identical.
Crescendo Audio :: Tweeters :: CTS-1 Tweeter Set
http://www.amazon.com/gp/aw/d/B004AONHQQ/ref=aw_d_detail?pd=1
Also the component set is 3 ohm, but I looked up both tweeters and they are both 4 ohm, just trying to do my homework, they seem like a well matched set of tweeters.
PM:
3XL-2S Specifications
Material:
Pure Silk
Size:
1.25"
Power Handling (RMS/Peak):
60 / 120 watts
Nominal Impedance:
4-ohm
Frequency Response:
3kHz-20kHz
Sensitivity (1W / 1M):
92 dB
Mounting Depth:
1"
CTS-1:
1" Silk dome tweeter kit
25mm woven silk dome diaphrams for accurate high end sound production
UHPLC copper voice coil
Optimized Neodymium chambered motor structures
Rated at 60w RMS per tweeter
Flush, angle and surface mount options
Full swivel functionality for easy adjustment of tweeter aiming/imaging
4ohms per tweeter/92dB 1w/1m sensitivity
Includes 2 CTS1 tweeters, 2 in-line 3khz/12dB defeatable Crossovers, full mounting hardware, and 3M double sided tape for testing out tweeter locations.
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
650
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
dross93ranger
dross93ranger
Maysville, KY
dross93ranger
    May 16, 2024
    May 16, 2024
