Build Upgrade 2005 Altima 3.5
Box is in place, new amp isn't in, but here's the placement, mid and High amp is on backside of board
Sent from my SAMSUNG-SM-G920A using Tapatalk
Seal off the front when its done
Sent from my SGH-T999 using Tapatalk
That's the plan! Put in side and rear bracing today, need to decide of I'm going to make the second run from the alternator under the car or inside. Don't know if I feel like drilling more holes in my firewall :|
Under the car is easier all around wiring but id personally never do it. Too much risk for me.
mine
mine
Dat seal though.. Yeah I feel the same, it would be extremely easy but I've bottomed out the car plenty of times as it is (It sits extremely low in the rear even with helper springs) So that makes me even more apprehensive. There's about a 4" gap on either side of the box, which makes me think I may be able to fill the entire gap with "big gap" expanding foam.. Would make it much easier than trying to fit pieces of wood as the side of the car is curved. Or.. I could tough it out, and try to cut some pieces that'll fill part of the gap, then fill the rest..
I cut out cardboard to fit everything first. Then transferred to wood. Just take your time. The top part has as much wood as possible but it has expanding foam on top.
From the back^^
From the front. I taped it off and sprayed so its unseeable from the front and its still really removable
From the back^^
Started tearing into the passenger side kick panel. Found the ECU wire harness grommet so if I find the motivation I might have the last two runs done today... Probably not lol. I have some scrap 1/2 inch MDF left over that I'm going to cut out to fill the majority of the gaps. It'll also be a smooth surface to paint so that's an extra bonus.. Doing all of this in a parking lot gets me plenty of weird *** looks, spent an hour or two last night sanding and cutting wood on the curb...
Second run, through the firewall.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif))
For soldering. I take a sealed copper lug. Cut a short bit of solder. Put it in the lug. Heat up the lug. It melts the solder and creates a puddle inside it. Then you dip the wire into the lug and leave it for a minute. Itll cool, expand and lock all around the wire and lug. Creates a clean awesome solder
**** yeah Id much rather use solid lugs, and a work bench, and a garage lol.. Anyway after making the second run I now have some interference on my RCAs //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Here's some more indepth info http://www.caraudio.com/forums/wiring-electrical-installation-help/628348-interference-after-adding-second-power-ground-run.html#post8838908
Amp update, db-r has stopped responding to my inquiries about the order I placed on 4 Sept... Left them a voicemail today, hopefully someone there has some answers.
So after leaving them a voicemail, I got an email within ten minutes about what's up.
The comments for your order are: Hello David I got your messages, sorry I
have been out of the shop alot lately. I have an order from Sundown that is
scheduled for Delivery on this Friday, but when I looked at the notes on the
shipment it just showed a bunch of small amps, I don't think the 6000's and
NS-1v2's are in this shipment, it's Ground and they probably are sending the
bigger amps by freight because of the weight, it's several 6000's and
NS-1's, that shipment should be in next week. I have been after them about
the orders and they say they have just been backed up in their shipping
department.
So they're most definitely back in good-guy status. DC-Power says they're finishing up the internal components of my XP270, installing that is going to be quite the task, on the 3.5L altima's you have to pull the radiator to get the alternator out. //content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif
Removed some braces from behind my seat that were covered in rust, sand and paint in the parking lot.. and here's my drying rack
Getting a bad vibration from the back of the box at certain frequencies.. doesn't seem to be a loose joint. When I put pressure at the center of the board the sound stops. It's MDF so I didn't think you could split it.. but I may be looking for a new box unless I can fix this with screws/glue lol
Added some pipe insulation to the top and bottom of amp board to stop vibrations (mid/High amp on backside). Expanding foam almost done. Going to use the terminal cup to put a dowel in to brace from the front baffle to the back.
timma100
timma100
Barksdale AFB
timma100
