big two???
  • 5
Beatin'
16
MI
I was reading something on crutchfield about the vehicles electrical system and one person in the comments section asked about the big three. Then a "Buck Pomerantz" from crutchfield said this....
Andrew, I believe that most of the benefits of performing "The Big Three" come from just augmenting the two ground wires you mentioned - battery negative-to-car chassis and engine block-to-car chassis. I would be very careful with the alternator-to-battery wire. The circuitry in the alternator includes diodes and current-limiters that you don't want cooked.
wtf is going on? Do you not need to upgrade the alt wire?
Alt pos to batt pos. batt neg to alt case. Alt case to engine block or frame.
alt case to engine block? its already bolted to the motor
OP do alt positive to batt positive(install fuse on this wire or 300amps for 0 guage). bat neg to chasis. and motor to chasis.
Block to chassis I guess. My stock batt is in trunk and only have the big two. Batt ground and batt pos done.
So is the guy right or wrong with what he said? He makes it sound like alt pos to batt pos upgrade isn't really needed.
Maybe for non-competitive systems?
With the factory alternator it's more important to upgrade the ground side. Watch this video' date=' skip to a bit after 2 minutes in to where Matt starts talking about engine grounds and such.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
Beatin'
Beatin'
MI
trumpet
    May 24, 2024
    May 23, 2024
