Big 3 with dual Kinetic batteries
  • 5
corysquires
AZ
I have 2 Kinetic 1800 wired in parallel with 0 Awg (+ to + & - to -)
For the big three do I just need to run a 0 Awg cable from the alternator to the main kinetic positive terminal? or do I need to do this on both main and secondary battries?
For the ground: I run a 0 Awg cable from the secondary kinetic negative terminal to the engine block? or do I run it also from the main battery, or both...
A diagram would be great if someone has one handy http://cdn1.caraudio.com/images/icons/icon6.png
i think your lost forget about the secondary battery for a minute ...... The 3 wires are:
- Positive from battery to positive from alternator ****fused****
- Negative from battery to ground
- Engine block to ground
heres a link that will help you out
How To Do The Big 3: Tutorial - Electrical-battery- Alternators- Wiring - SMD Forum
then on to the secondary battery
1 run from positive of primary battery to positive of secondary fused on each end as close to the battery as possible
1 run ground to ground and done
hope this helps as its straight forward good luck op
The big three up front should be fine but I've also seen people run an additional pos line from alternator to secondary battery (fused of course) this I'm not sure is necessary I guess depends alt size.I would run a neg line from front battery directly to secondary battery neg
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
corysquires
AZ
supra1987
    May 16, 2024
    May 16, 2024
