Big 3 upgrade wires
  • 2
javisam376
21
NY
Hey guys, I am about to perform the big 3 upgrade on my 03 stratus SE, which only has remote battery terminals from under the hood (the battery is located in front of the left front wheel and to access it you have to take the wheel off and remove the protective guards, which makes it very difficult to reach)...
I was wondering if I can do all the conections to the remote battery terminals and then replace the wires from the actual battery to the remote terminals... would that work??? my amp is currently wired to the remote terminals...
Thanks...
Should not be any difference from either spot. Another member asked the same questions about a few weeks ago or so. Search for his post and PM him for his results.
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
958
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
javisam376
javisam376
NY
loopkiller
    May 24, 2024
    May 23, 2024
