Best speaker wire terminal?
throatrattling
Canadian Guy
614
Toronto
Just finished a box build, and I really didn't want to put a plastic speaker terminal on the box for multiple reasons. Just ran wire through the port for now. I see a lot of guys using threaded rod, and I'm just wondering how good that method is, and how you properly seal that after. I'm open to any other suggestions as well.
On another note, is 8 gauge wire sufficient for running 1500rms to a single sub?
Any feedback is greatly appreciated, thanks in advance.
Bolts are easy, just seal it up with caulking when you put the bolt through the hole, use washers and it won't come out.
Agreed, for larger gauge wire I usually use bolts or just drill a hold in the box and feed the wire straight through. Just make sure to seal it up.
For smaller gauge wire I really like using these:
I use brass bolts and aluminum lugs would use copper lugs but they tarnish after awhile so I just stick with a heavier aluminum lug //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I think he wants to use the existing enclosure he has, and its cut out for a single Ten inch sub at the moment
19
It is a completley new truck except for what is painted red. It has a TCI custom chassis, four wheel disc, four corner adjustable coil overs ...
Definitely hard to beat, but they're deep. Didn't know these were still floating around.
13
Yes. That is another factor I like about Polk Audio speakers. They can dig a bit deeper than the majority of components within the same price...
4K
throatrattling
Canadian Guy
throatrattling
Toronto
madcad95
    May 24, 2024
