Bama's build
I just got done installing the 80prs and ran temporary wires for some cheap 6.5 coaxials, I now know the hype on the 80prs this thing sounds really good without any tuning
Sent from my SM-G935V using Tapatalk
id build you some drivers but they wont be a "bargin" lolim getting a pair of 9500i motors to build some drivers to do SS1-2 aka modified.
No thanks, I hate to have regular cookie cutter subs but them one offs are hard to resell
Got a little work done today, dash most of the way put back together, my first step in getting something done with sunroof. I used window weld to try and secure it while I take the track and motor out, I'll let it dry till tomorrow mid morning then see if it holds and secure it with wood somehow.
i'm sure my sunroof kills my scores. how did that window seal do? ill swear by that 5ton epoxy lol...me and a friend used something similar. was about 25 bucks. didn't workout very good.
It held it in place while I took the track down, I'm going to use some pl 8x on the bottom and frame it around the edges with wood.
Fan of four 18s as well. Knew a guy with four AA 18s years ago and it was amazing.
That's what I'm thinking, I'm just not sure on which ones, I'm liking the soundrive sda3 just don't have a lot of info on them and haven't heard them in person
Whats the budget your working with just for subs?
Sent from my Moto G (4) using Tapatalk
i try to keep it simple. sometimes you never can get all the varibles in check and waste alot of time and money.
id even look into the two judge 21" drivers. you can easily get good coupling between tbem and the port with the right confirguation. 1 21 is like 2 15s so you should be high 150s with 6k per plus you have the freedom to move the configuration to better couple you sinewaves
bamaman
bamaman
Phenix City, AL
bamaman
vegang
vegang
