Adulbrich's batteries
It's not hooked up so its not playing. That's how... And 160 isn't easy... U can have all the equipment and still not break a 155db
im about to sell my car. unless i can find a oldschool blazer in prestine condition cheap. im about to dump a killin in a few protypes for testing..
motors are being built and coils are done..
im about to sell my car. unless i can find a oldschool blazer in prestine condition cheap. im about to dump a killin in a few protypes for testing..motors are being built and coils are done..
And I doubt anything you build will ever break a 160db under 40hz //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
kmsl. dude ive done low 150s with single 15 and 2kw, can you imagine what id do if i had 4 18s and 12kw?
Between each battery, I could have a 4" piece of 1/0 monster cable. They've got tinned copper lugs that are solid. I was going to make five banks of six batteries. With six batteries in each bank jumped off each other, do I even need bus bars? I'd rather not have to make any. The wire between batteries is so short...
Only 4" of insulated wire:
Wire and lugs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
387
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
adulbrich
