Adulbrich's batteries
Way to svck up to the boss man on the first day of work..Lol..//content.invisioncic.com/y282845/emoticons/applause.gif.bb805d8088f72dbc2fe808c29e85fb4c.gif
I run a walmarts battery but six banks of supercaps, shot a lightning bolt out the side of my vehicle the other day and hit some lady's car at the stoplight next to me. She wanted to race but I shut her down with a EMP pulse.
nothing wrong with used batts
The 3 I got the guy put a 100a load tester on them for 30 sec and they hardly dropped
If anyone remembers the stinger spv's that were floating around here used my last one is finally not preforming 100%
And that is around 5 years of hard use on a used battery
Great buy
You can probably make a couple bucks if you wanted to sell a few
I replace my batteries every 3years. Lol so they don't go bad on me. And here you are buying three year old batts that could go bad anytime... I hope they work out for you.
They're barely used and load tested great
how much is the total output of the alts? 4 300s should be fine for 10kw. no voltage drop
370, 320, and 300
i need your job. 4 alts 3 wardens 10kw yea u balling
Correction. 21kw before rise
Yeah, lol
RIP 4L60e.
Transmission?
A car audio shop I found sales different telecom batts. That were used by I guess like cell phone towers or something that kept a float charge on them. After like a year they sell them to them and they resale them like $150 for the 100+ ah ones and $75 for the 80ah ones.
Yep, transmission. By the time you factor in all those batteries and a wall, it's not going to like it long term. Be sure you've changed your transmission fluid on schedule and maybe consider a cooler unless you want to be replacing it with a 4L80e.
Had it flushed During the Summer. Might again after installing the batteries then
I'm getting 2500 leaf springs after my next paycheck. Then I guess I'll save up for if my transmission goes out, lol
No need to flush it more than once every 3-4 oil changes even when abusing it. Like I said a good trans cooler would be a good investment for longevity. Or be on the lookout for a reasonably priced low mile 4L80 / 4L85, since a built 4L60 is going to run about $2k. But with an upgraded transmission you'd be good to go, they're definitely the weak point in these vehicles.
Your truck might have a stock trans cooler, mine cane with one but I'm pretty sure it has the tow package. It's a little square in front of your radiator
387
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
adulbrich
