accidently hooked ground and power up backwards
I have 2 more questions about this b4 I throw in the towel. If the power line fuse blew could it still look normal like nothing is wrong with it? Also if the fuse is blown should that keep my amp from coming on at all? Like for instance if the power line fuse is blown should my amp still come on even though its going straight into protect mode?
When I unhook the rca's and the speaker wires the amp will come on the protect light will come on then go back off but the green light don't come on at all. So it kinda makes me feel like the only power its really getting is from the rca's and the signal wire?
Fuses can blow sometimes and still look ok but not very often. You can check for continuity through the fuse with a multimeter if you have one to see if it's blown. I've never seen an amp try and turn on without a live power wire hooked up though.
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
Yeah I saw a lot of that when doing those installs as we also did surround sound system wiring as well. I always ended up being the doing it as...
Babykinns
Babykinns
Nelsonville, OH
Babykinns
    May 12, 2024
Brendon Jenness
    May 11, 2024
