accidently hooked ground and power up backwards
First off, be sure of your sub's impedances. Are you positive it is a 2 ohm final load?
While Kicker amps aren't horrible, there are better options. You said those subs are 600W RMS a piece? What's your budget?
400w rms a piece and d4.
go look at audiopipe apsm1300 would work well, just sold mine for $65.
100% positive that they are 2ohm and they are rated for 400-800 watts rms a piece i mean these subs can easily blow windows out of a car i got mine in a 92 honda prelude and i couldnt even crank it that load bcuz it would flex my rear windshield so bad it started to crack and tbh my budget wont be much bcuz im only 23 n got a 1 year old son and fiance to take car of but i come across people trying to trade or sell amps a lot so could you give me a small list of what would be a good mono or 2 channel amp for them? tbh the scosh amp i had was actually a pretty good amp but i was testing out another amp i had to see how stable it was with the kickers bridged n it went into protect mode n wouldnt come out n i got mad n got tired of ****** wit it so i got into a rush to just hook my scosche amp back up n thats when i accidently hooked it up wrong cuz the power and ground spots on the 2 amps are the opposite and i was in such a rush i forgot all about that
well im off to bed guys got work early in the morning but any advice or tips would be greatly appreciated and thanks for all the help and advice some of you have givin me yall take car and have a good night ill be on tomorrow or sometime take it easy
100% positive that they are 2ohm and they are rated for 400-800 watts rms a piece i mean these subs can easily blow windows out of a car i got mine in a 92 honda prelude and i couldnt even crank it that load bcuz it would flex my rear windshield so bad it started to crack and tbh my budget wont be much bcuz im only 23 n got a 1 year old son and fiance to take car of but i come across people trying to trade or sell amps a lot so could you give me a small list of what would be a good mono or 2 channel amp for them? Tbh the scosh amp i had was actually a pretty good amp but i was testing out another amp i had to see how stable it was with the kickers bridged n it went into protect mode n wouldnt come out n i got mad n got tired of ****** wit it so i got into a rush to just hook my scosche amp back up n thats when i accidently hooked it up wrong cuz the power and ground spots on the 2 amps are the opposite and i was in such a rush i forgot all about that
gtfo
Bout it. First the subs were 400-600W a piece, now 800. You are not blowing windows out with those. Your glass did not start to crack. Not without physically beating it with those subs. And you didn't think to mention that the last amp you had in there also went into protect??? //content.invisioncic.com/y282845/emoticons/wallbash.gif.1310150c49dd52e0fbe1813a0681e5c3.gif
Dude, just take care of your family. Don't waste money on something you're just going to blow up.
let someone with a little more experience hook your amps up for you.//content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
I accidentaly did this once. To a $1k amp //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif just blew my inline fuse. Amp was fine.
I did this on some crappy Nitro amp I had, because the pwr and gnd terminals are opposite of most amps, so I was just going by muscle memory. Blew the inline fuse, replaced it, and had no problems.
The biggest piece of advice I have for you though, would be to use some motherfucking punctuation. Your posts are almost rendered entirely unintelligible because you manage to avoid commas and periods like the fucking plague. ENGLISH. If you can speak it, type it. It makes everything so much easier to help you with, and so much less frustrating to sift through.
Now that being said.... I did manage to pick up that you think your Scoshe amp is good. It's not. It's a very low quality amp. If you can afford a new Kicker amp, there's a lot better value amps you can get used that will perform just as well, if not better.
Also, you said something about those mediocre subs, on your mediocre amp, in (what I'm assuming is) a mediocre prefabbed ported box, somehow managing to not only flex your rear window, but actually start to crack it? I know that to be a bold face lie unless you're an expert in acoustics, and already had a badly damaged window. I've been in much louder cars and seen some significant flex, but I've never seen a broken windshield be the end result.
I did this on some crappy Nitro amp I had, because the pwr and gnd terminals are opposite of most amps, so I was just going by muscle memory. Blew the inline fuse, replaced it, and had no problems.The biggest piece of advice I have for you though, would be to use some motherfucking punctuation. Your posts are almost rendered entirely unintelligible because you manage to avoid commas and periods like the fucking plague. ENGLISH. If you can speak it, type it. It makes everything so much easier to help you with, and so much less frustrating to sift through.
probably threw one at the window to pull that off. LOL
Woah slow down there bud. No need to be disrespectfull. I said they were rated for 400 watts rms - 800 watts rms max double check my posts. The first amp went into protect because it couldn't handle my kickers apparently I even called insignia and asked them if it would be safe to bridge them. I told them my subs were 2 12" kicker cvr's with dual voice coils wired at 2ohms and they said it should run them fine bridged as long as I kept the lpf/hpf switch on full. And also I know how to hook **** up the main reason I accidently hooked my scosche amp up backwards is because I was pissed because the insignia tech guy lied to me about the amp being able to handle my kickers in bridge mode.
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
Yeah I saw a lot of that when doing those installs as we also did surround sound system wiring as well. I always ended up being the doing it as...
Babykinns
Babykinns
Nelsonville, OH
Babykinns
    May 12, 2024
Brendon Jenness
    May 11, 2024
