3500 watt 15
I would probably do any one of those except the DD. 3" 4 layers won't appreciate 3500w daily (at least not for long periods of time).
that *****. wat car? i fit a level 6 to fit in a 98 escort zx2 lol
Scion tC. The most i can get without moving to amps up right behind my head is about 5.5 gross. Its a stupid layout in the back. The hatch lid cuts the box off to only be 10 inches high so I can only mount inverted which has to be low enough to give some space from the roof. 36 x 36 x 10 is all i have. If I gutted to entire hatch i could do a 18 but that would mean a ton of work that i cant do right now. Its going to get a wall when its paid off so I'm not trying to reinvent the wheel till that time comes.
5 cubes after displacement works perfect with that much power. could do 4.5 cubes and be golden
After port I can only get a bit over 3.5. It has to be a long mouth port right under the hatch. That takes up some space. I've tried a few different boxes, none have really impressed me so far. The one I have coming next week is a bit different then the others, if it works i'll do the same with the 15
mayhem>zcon
mayhem is a beast daily drive sub, can take a beating. I like my zcons but that much power daily might be pushing it, I know guys do it but idk how long they'd hold up
exactly no 4 layer coil will handle that power daily. alot has to do with ur rise too because clamped 3500rms more than half the list would fail...
I will be easy on it unless its a demo. With 3.5 rise " should " be minimal. In your opinion which would be better suited?
yea any 3500 watt amp after rise is usually around 2-3k realistically so you should be fine with that level 5 m2. they have way better cooling now too so thats great for daily.
mayhem>zcon
Um, they should both take very similar power.
i would do a nightshade because it has great cooling.
a 3.5" coiled sub i would run from because its odd and only get stock recone and if they run out of coils or they **** ur stuck..
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
LosIsATool
LosIsATool
Pensacola, Florida
LosIsATool
    May 16, 2024
    May 16, 2024
