3500 watt 15
that *****. wat car? i fit a level 6 to fit in a 98 escort zx2 lol
Scion tC. The most i can get without moving to amps up right behind my head is about 5.5 gross. Its a stupid layout in the back. The hatch lid cuts the box off to only be 10 inches high so I can only mount inverted which has to be low enough to give some space from the roof. 36 x 36 x 10 is all i have. If I gutted to entire hatch i could do a 18 but that would mean a ton of work that i cant do right now. Its going to get a wall when its paid off so I'm not trying to reinvent the wheel till that time comes.
5 cubes after displacement works perfect with that much power. could do 4.5 cubes and be golden
After port I can only get a bit over 3.5. It has to be a long mouth port right under the hatch. That takes up some space. I've tried a few different boxes, none have really impressed me so far. The one I have coming next week is a bit different then the others, if it works i'll do the same with the 15
exactly no 4 layer coil will handle that power daily. alot has to do with ur rise too because clamped 3500rms more than half the list would fail...
I will be easy on it unless its a demo. With 3.5 rise " should " be minimal. In your opinion which would be better suited?
i would do a nightshade because it has great cooling.
a 3.5" coiled sub i would run from because its odd and only get stock recone and if they run out of coils or they **** ur stuck..
LosIsATool
LosIsATool
Pensacola, Florida
LosIsATool
