2014 Focus ST build Sundown SD 8s
UMWDawg92
Missoula, MT
So I picked up my new ride in October and it came with the sony premium audio which was weak as hell so I decided to upgrade. I figured I'd start with the substage as the factory speakers aren't that awful.
I want to do this as more of an SQ build than anything. I have been intrigued by the Sundown SD8s for awhile and saw an opportunity to use them.
Equipment list:
Sundown SD8 d4s x3
Sundown Saz-1200d@.66ohms
All wiring is Knukonceptz
Knukonceptz kolussus 100mil sound deadener
Old school rockford Fosgate punch 250a2 and some PHD passive crossovers
Audiocontrol lc7i
I had a 2003 Focus SE. I beat that little car senseless. Finally puked in LA while I was on an inspection job. 295,000 miles. Good little cars.
Are you guys familiar with the ST's at all? I love it so far, small hatchback with a lot of power. I've already done intake, 3 inch turbo back exhaust, intercooler, intake runner/plenum spacer and a custom tune. I need to dyno it but I should be at ~270-285 HP at the wheels and about 350-370 torque. This summer will likely bring some more go fast mods and my front stage upgrades.
I really hope Jacob gets the Sundown Xbl2 comp set he's been working on going then I would do an all sundown SQ build. It doesn't look like my pics are working so I'll fix that.
The SD 8's are going to be about 1.25-1.5 cubes sealed for the 3. Its a little on the large side but will let them dig a little deeper and they will fit a little better with the extra depth. I'm going to fiberglass the enclosure to fit over the passenger side wheel well. The hatch after the first layer of glass was laid down.
I got the speaker rings cut. I ran out of 3/4 inch mdf so I used some 3/4 hardwood plywood to finish it off. I decided to flush mount on these as I think it will look better.
I got it all wrapped up in fleece and soaked with resin. I decided to deaden the hatch door while it dried. Then afterwards I did a test fit.
---------- Post added at 10:31 PM ---------- Previous post was at 10:30 PM ----------
I got the box wrapped up in carpet and installed. I should have taken more pics of install, but I'll update a lot more this summer when I do my front stage and electrical upgrades. The outer door skins are deadened and I wired in a set of PHD crossovers on the factory comps. They are being ran off of an old school rockford fosgate punch 250a2 getting about 50 per side. They sound quite nice considering they are the factory set.
I am thinking about doing a full sq build in this car. It's my daily driver right now so I need to keep the space in the hatch. Otherwise it may have been 6 sd8s off of a saz2500 or sa8s. I have to say though I'm impressed with the SD8s for their performance in small sealed, good output, they get low, and best of all they are extremely clean sounding.
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
977
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
679
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
986
UMWDawg92
UMWDawg92
Missoula, MT
UMWDawg92
