I'm trying to find these insulating tiles locally. I checked out the Lowes and Home Depot websites, but I'm not sure what these things looked like before you cut them down. Would so be so kind as to provide me with a product link?4 hours of effort treating the passenger door. that's deadening, absorption, MLV barrier and CCF decoupler, and then terminating the speaker wires i had previously ran into the door. tomorrow i will repeat for the passenger door. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the passenger door needed deadening, so a few sheets of BXT II did the trick.
then came the most important part of treating a door - adding absorption. this is a 1" thick compressed fiberglass ceiling tile (with the white cover removed). $6 per 2'x4' piece. this is easier to work with than the loose batt insulation and being compressed it offers more absorption with less hassle.
next came the barrier. the factory barrier is thin. i wanted to use MLV for the barrier but had the challenge of keeping water out. the factory setup has a slit where water can drain but it is flawed. so i added Ensolite (CCF( to the metal where the MLV will contact and also to the entire inside (one piece, sticky side out) to stick to the MLV and create a watertight barrier.
They have a thin white plastic covering. I have a photo in Lowe's I will find.I'm trying to find these insulating tiles locally. I checked out the Lowes and Home Depot websites, but I'm not sure what these things looked like before you cut them down. Would so be so kind as to provide me with a product link?
This is what you sent meThey have a thin white plastic covering. I have a photo in Lowe's I will find.
Sent from my SM-G900V using Tapatalk
A clean signal is what I wanted. Something I can work with. I didn't expect it to be flat. Yes, mission accomplished. I am happy the front is the same as rear, because the front has hands free calling on it.Is that what you are aiming for?
I was thinking that was acoustic.A clean signal is what I wanted. Something I can work with. I didn't expect it to be flat. Yes, mission accomplished. I am happy the front is the same as rear, because the front has hands free calling on it.
I would prefer a flat response but a MiniDSP can get me there.
Note the above are directly from the HU, not a mic measurement.
