keep_hope_alive
Premium Member
Acoustics Engineer
- Thread Starter
- #136
Before I removed the amplifier IC, I did some bench testing with a test CD that contained pink noise, 500Hz tone, 40Hz tone, and 20Hz tone. Tones were generated in Goldwave and full signal strength.
I had a speaker connected to the output while taking some readings at low volume, and both worked. Adding the scope didn't generate noise. Doesn't matter now that the amplifier IC is gone, but my original plan was just to tap the pins and not remove the entire IC.
The bass roll-off still exists, but we have ZERO clipping up till 99% volume. These measurements are at the RCA jacks I installed. Also, the HU volume control worked, a good thing for those wanting to use the stock HU by itself.
500Hz tone, 39/40 volume, 2V P-P (0.5V/div)
40Hz tone, 39/40 volume, 0.5V P-P (0.2V/div)
20Hz tone, 39/40 volume, 0.16V P-P (20mV/div)
I also measured pink noise at full volume, 1V P-P average with 2V P-P peaks
