10" sub Poll
Which 10" sub should I get?
  • Total voters
    14
P Chamber is for better cooling if you put on 1500 rms etc. The heat ring is for burping. And spiders ate for better Spider control. Direct leads are where there are writes coming directly off the sub instead of push terminals. Helps prevent lead slap.
On the dsc I would just get a stock ssd. You won't have to worry about any upgrades beside the high qts for sealed. Subs become less sealed. The other options are for large ported boxes to gain sub control
So no on the cooling option or the flatwind coil? I thought the cooling option would be good but the flatwind coil is just for putting more than 1000 rms to it right?
Both are for more power in a sealed box on 1k you don't need any upgrades. If anything the cooling will just help if you decide to get more power but won't require more power. The coil will want more power
sjuddslvrss
sjuddslvrss
Rochester MN
mclerico83
