10" sub Poll
Which 10" sub should I get?
  • Total voters
    14
[quote name='av83']@Dtrom ; has d4's for sale. you can probably get two, for the same ohm load, for nearly the same price as one d2. if you have room, that is.[/QUOTE]
Thank you sir. I have the I-series incriminators op. pm me if your interested
what amp u have? you already have a box, or are u going to make one for the sub you buy? sratch the RE out of there
get an aspm 1500, i have a rd sonance motor that splaudio could build to take that amp at 1 ohm :)
@SPLaudio ;
at 4 ohm those amps are crap and you might as well buy a nice 2 channel, ps there are better amps for 150 and under
i would mail the sub to splaudio for 40 bucks with frame save you some money and youi will get a custom built hand built sub and he could custom build it for a sealed box
SSD10 - Fi Car Audio Store
if you dont want to go with spl custom sub this would be my next choice
get d2 and it could take the aspm1500 easily with the cooling option. and if you get the high-qts option you are getting the sub built for sealed boxes specifically.
this would be mine over any you previously mentioned.
What amp and sub would you recommend then. The only variables that are set in stone is I'm keeping the stock alternator and battery, the sealed .6 cubes, I will do a big 3 upgrade, and I want SQL.
sjuddslvrss
sjuddslvrss
Rochester MN
mclerico83
