Well I been working on this pretty much every night when I get home from work. Past three nights I have been up till 11pm or later trying to get as much done as I can and then put it all back together so I can drive it the next day. Doesn't feel like I am getting much done but I will let the pictures tell the story.
I came up with a way to bolt it into the truck so it won't be relying 100% on the seat to hold it in place. Folded over some of the metal I used for the computer area, then screwed through it into the cab and into the mdf. Its also bolted to the floor using some of the factory bolt holes for the junk I pulled out.
Carpeted the visible sheet metal so it would blend in with the amp rack.
Test fit, starting to see the final product.
Here we go, seat is in, amp rack is in and now all I gotta do is start running wires and get it to make some sound.
Its a tight fit, almost a bit too tight
Started fiddling around with mounting the screen and such in the dash. Still a ways off before I start this part of the project but nice to see how things are going to look.
Today I got the speakers in and all the wires run. I haven't had much listening time but its sounding pretty good. Ended up running into a snag though, one of the crossovers is messed up, seems something in the tweeter network is screwed up, so after trying everything I could I ended up bypassing the crossover for just the tweeters and set up the 100.4 so the tweeters won't die playing some low notes. Still gotta fiddle around with mounting the tweeters though, right now they are taped up on my sail panels, going to try the top of the door panel and maybe a few other spots as well as some more tuning. Gotta deaden the doors in the future too.
Oh and I put in my order for the new mags, should be here sometime around the end of August or beginning of September. Hopefully I will have a nice home for them by the time they arrive.
