Featured 2023 Chevrolet Colorado Trail Boss
I wonder if auto manufacturers now do this because radios are very integrated that they have become expensive. Good thing that Kicker foresaw this issue and built in the resistor.
Are you talking about the module brackets or the ABS beauty side panels?
Change for 2025
Stinger MT1000.5 (bought)
AudioControl LC7i Pro (bought) (@ibd23281 on diymobile)
CDT Audio CL-69SUB CF (Front Doors) (bought) (spokey9)
CDT Audio Unity 7.5 (Dash) (bought) (From CDT)
CDT Audio EX30 crossover (bought) (From CDT)
CDT Audio CL-6EiX (rear doors) (bought) (From CDT)
SI M25 MKII Tweeters (Traded on DIYMA)
Product highlights:​
  • 10" 2-ohm subwoofer
  • polypropylene fiber matrix paper cone with mica coating
  • rubber surround
  • stamped steel frame
  • power handling: 400 watts RMS (600 watts peak)
  • frequency response: 20-250 Hz
  • sensitivity: 86 dB
  • top-mount depth: 3.5"
  • sealed box volume: 0.4-0.8 cubic feet
  • ported box volume: 0.9-2.0 cubic feet
  • metal mesh grille included
Subthump Enclosure
Approx. Empty Weight: 26 lbs
MDF Construction
Installs under rear seat
Plastic cover and support bar must be removed for box to fit
Box is held in securely by seat
No modifications to truck are required
Speaker fires down with
1-1/2" of box to floor clearance
Fits one 10" shallow sub
Will also fit JL 10 TW3
Normal Cutout Size=9-1/8"
Mounting Depth: 3-1/2"
with restrictions-see below
Volume: .90 cu.ft
Sealed Box
  • rubber surround
Those box parameters are sweet, no need to worry of the enclosure being too small. Can't wait to hear your opinion on their performance.
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
AnthonyO
michigan born
    May 14, 2026
michigan born
    May 14, 2026
