My 1969 Corvette restomod AV-build amp problem
Andy McKoi
CarAudio.com Newbie
Hi,
Working on a 1969 Corvette restomod. Car is almost complete, on agenda for this winter is the audiosystem.
Wanted to "cold run" the system outside car before installing it but run into a problem. Can't wake up the dsp/amp (Match UP7DSP).
I have a fresh car battery with good voltage. Dsp/amp connected to the battery and measured that voltages are fine both at the battery and at the dsp/amp terminal.
Hot wired the "REM" (wake up wire input) from the + terminal. Again measured and the voltage there is fine about 12V.
Yet, the dsp/amp is not waking up. Opened the case and the two fuses inside are intact.
The LED indicator light on the amp does not lid up no matter what I try and the PC with the adjusting software for the dsp does not recognize the anything would be around for a connection.
Any ideas? Good it just be a dead dsp/amp or any tweaks one might try?
Thanks in advance!
Build Photo
  1. Not right now
Andy McKoi
CarAudio.com Newbie
Andy McKoi
Finland
AnthonyO
