Downtownbrody
I'm looking for recommendations on a single 12" sub around 2500w RMS, trying to stay below $600. I will be using WinISD and probably SubBox.pro to build my own box.
I'm not looking to compete, listen mostly to rap and hip-hop, looking for loud as possible, but not low as possible (probably in the 28-50hz range are most important). Sound quality is important but not as important as spl.
Amp I'm working with is 2700w RMS @ 1 ohm, 1950 @ 2 ohms, 1250 @ 4 ohms. Electric could be better, but have a secondary battery and 250 amp ho alternator.
Trunk space is somewhat limited or I'd go up to a 15". I've built a 2.5 cu.f. for an American Bass XFL and it fit nicely but could barely get it in. 12" is the max I could fit with rear/front facing speaker due to height restrictions, worried if the speaker was on top it would bounce into ceiling of trunk. I might be able to go to 3 cu.f.
I've considered the following subs, but not sure if there's one that fits what I'm looking for better than the other OR if there's something else out there better:
*Deaf Bonce Apocalypse DB-3012R
*B2 Rage XL (RMS rating, enclosure recommendations, and t/s parameters are all over the place on this one which is driving me insane, red flag)
*Resilient Sounds Onyx
*Orion HCCA12
Thanks in advance for insight and/or advice
*Orion HCCA12
