what should I do
  • 5
wcabra
I have 2 Rockford Fosgate p3's and 1 jlaudio W7 1jlaudio 1000/1 (12's speaker size) Is there an advantage to hooking them all up or would it be pointless i.e. the w7 drounding out the p3's? also want to know if the three subs can run off the one amp? let me know and thank you guys!!
It is never a good idea to mix and match subwoofers. If you have to ask definitely do not attempt this!
W7 in a proper box on the 1000/1 should be a great sub-stage. No sense over-complicating this, and if you really do need to get much louder and have enough space for so much cone area there's probably better ways to get there.
its in a red eye box so the box is good but i have these laying around and though maybe a project?
Those JL built boxes are pretty good, you could get a little more output building your own but probably not worth the cost of wood if you don't enjoy a carpentry project.
Don't mix and match subwoofers, results will be unpredictable (but probably poor) and you risk damaging your subs because the amps will not be delivering the same power to everything ever.
There may be ways to run multiple different woofers in a vehicle effectively but it will not be worth the trouble.
Thank you!
I would run the P3s for about a week, then run the JL for a week to see which of the two you like best, and run it.
I'd almost wager the 2 p3s in a properly built ported box would be a fair bit louder than the single w7 on the same 1000w.
But once you compare the xmax of the w7 at 29mm to the 15.3 of the p3 they become much more similar. I'd probably run the w7 just for space savings.
The CT's are nice, That Sundown is a a frik'n beast!
495
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
439
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
538
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
862
wcabra
wcabra
springfield
Bobbytwonames
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
