Featured how should I hook this combo up
ttt123
CarAudio.com Recruit
I loaded up a pic of the amp specs. I just got it yesterday. this is an NVX VAD17001 "mono block" and I'm using for subs a pair of new NVX 10" that say 1000 watts RMS (sorry don't have a pic of those on my phone)
I'm an older guy but still love my bass but tech is not my strongest .. umm ... I'm dumb lol you guys have helped me hook up and figure a bunch of stuff out over the last couple years so just looking to lean on everyone's knowledge if that's ok.
what would be the best way to hook up these 10's to perform safely? Meaning.. I don't have top of the line stuff and not trying to win any competitions but stuff like 1 ohm, 2 ohm and 4 ohm... I don't even know what that means lol I read something about running 1 and 2 ohm set ups can create heat that can overheat amps and stuff like that. I just want to hook it up and have an amp that can push these 10's safely.
I've tried a few cheaper amps with these subs I had laying around and ... they don't move these 10's. they are some seriously stiff speakers. I've hooked them up to a Punch 800 watt amp and a Memphis cheaper amp and it ... ya they couldn't move these speakers. I think .. THINK I hooked them up correctly at 4 ohms.
Any advice would be appreciated and thank you guys for any input... you guys always rock when i post in here.
oh and I have these subs in a ported box that is matched to the makers specs which if I remember correctly is 1.1 cbft. I bought the box so it should be solid and support the requirements.
Knowing the exact impedance of the subs you bought is important to be able to wire them up correctly.
That amp is 1-ohm for its highest output (from a quick look), so hopefully the subs have the right impedance to achieve that.
Post the specs / exact model of the subs you have sitting there when you get a chance. A photo of the specs on the magnet or cardboard box to make sure its accurate info would be good. Then someone can give proper wiring info.
I will do that when i get home later from work. i know these are the better NVX 10" subs they sell. but i will post up a pic.
thanks for chiming in.
ttt123
ttt123
michigan
ttt123
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
