Can you give us a little more info about where you heard this in reference to subs?Hello as it says at the title what is vacuum and can anyone give me some advice how to avoid vacuum and maybe some examples. Answer would be really appreciated.
What i know is that its not good but it also depends
because i have a L port and i cant have the subs behind the port because i would suffocate the subwoofer.Can you give us a little more info about where you heard this in reference to subs?
The only thing I can think of is a sealed box that is not fully sealed, and something is acting like a check valve at the "hole" that lets air out but not in.
Cone moves in, pushing air out, then the hole gets "sealed" and there is now a slight vacuum.
That looks fine. You want to keep away from the port opening as much as possible, but I don’t see a problem with your design.because i have a L port and i cant have the subs behind the port because i would suffocate the subwoofer.
Wait here the subwoofer box. The problem is if i do like this i would trap the air behind the port wall
Subwoofer box DD Audio Redline 612e D4
12 inch subwoofer box design DD Audio Redline 612e D4, ported box plan, 3D model. Net internal volume 3.35 cubic feet, port area 50.00 square inches, tuning frequency 33 Hz. Subwoofer box calculator onlinesubbox.pro
Seconded.That looks fine. You want to keep away from the port opening as much as possible, but I don’t see a problem with your design.
What sound reasons?You can make a U or an S port. Here's an example:
I like to do this type of port when the box isn't very deep, sometimes, when it's advantageous. There's also some specific sound reasons to do a port like this, but that's an entirely different discussion.
What sound reasons?
Way beyond the scope of what you are trying to do and more into the realm of creating "transmission line" alignments. For your purposes the less bends you have in the port, the better, and you should keep things at least the width of the port away from the port mouth inside and out if possible.What sound reasons?
Doesn't this apply to all subwoofers? Brain-picking, not nitpicking.Assuming you are using DD subwoofers they are specifically designed to perform well in the boxes DD recommends on their website. If you put a DD sub into a properly build DD specifications box it will perform very well. I would suggest you use the largest recommended box size for your sub(s) that is practical for highest output.
According to DD's published design philosophy they start with the box then build the sub around that so I'd imagine they probably test prototypes by throwing them into cookie cutter DD spec boxes to see what works best. Not sure who else has a cookie cutter box design that does well with every line of woofer they produce, or who else starts with sounding the way they want in a specific box as a primary goal when designing their product.Doesn't this apply to all subwoofers? Brain-picking, not nitpicking.
okay but i dont get why you shouldnt have the subwoofer to close to the port. my car doesnt have much space but i know i can fit themWay beyond the scope of what you are trying to do and more into the realm of creating "transmission line" alignments. For your purposes the less bends you have in the port, the better, and you should keep things at least the width of the port away from the port mouth inside and out if possible.
You should be very happy if you build the DD box plans so long as the box is built out of good thickness material and all seems are airtight and solid.
The thing we are trying to avoid here is "turbulence" (my guess is you mistranslated this).okay but i dont get why you shouldnt have the subwoofer to close to the port. my car doesnt have much space but i know i can fit them
