Amp wiring
If I have an amplifier on one box already can I just use distribution block for ground and power and add an amp
Yes you can add a matching amp to the other set of subwoofers. You just have to gain match the two amps so they are putting out the same power, and have the same crossover settings.
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
794
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
902
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
fjack
fjack
New York
fjack
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
