Need help asap subwoofer problems
I was just curious if he might be wired to ½ ohm.
I thought about that too, but that smart 3 will do .5 ohm all day long. I just didn't want the OP to be thinking about too many things at once. That's all. Figure out the electrical upgrade, then make sure them subs are wired correctly. The smart 3 is kind of idiot proof doing 3000 watts .5 ohm-2 ohm
That is one nice option they did with that smart 3 should be able to do 1/2 ohm and lower voltage. But if memory serves don't those require 1/0 on the power and ground? Plus who knows if that 4 gauge is ofc or cca.
You would think a 3k amp should be 1/0, but if you read the manual, it says 4 awg 🤷‍♂️ that's beyond me as well.
And yes, let's hope that 4 awg isn't CCA
The manual says 4 gauge minimum and up to 1/0 gauge. He needs to run 1/0 gauge.
Im not op as well just saying rude ass
Doesn't OP mean original poster? I wasn't trying to be rude dude lol. Just saying an amplifier that can do the same output at 2 ohm all the way down to .5 ohm is kind of idiot proof. Wasn't calling you an idiot
Sorry brotha just tryna get some help you know lol my bad again..... i know my **** hit because ppl turn they neck when im riding around at almost max volume but that one button to high cuts it and ik it hits harder than most trucks in my area they be looking at me too lol
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
113
705
752
970
Bassboosted4000w
Bassboosted4000w
Bobbytwonames
    May 19, 2024
    May 19, 2024
