Hello
I have two 4000w subs with a 1 inch box
Also i have a smart 3 taramp 3000w amp
With 4gauge wire. Amp keeps going into protection and turns right back on after certain volume they hit hard untill i push the volume to high??? Plz help do i need 0gauge wire or another amp
I'm not saying that Rockville ***** by any means. Let me start off with that. However, I am going to say that Rockville is by far unable to accept judgement or constructive criticism. If you haven't been following them, let me fill you in on what has been happening. About a year ago, a YouTuber...
Ok. I will be getting 2 PSI Platform 2 HD 2ohm subs.. I currently have 2 rockville rxd-m4 6000w mono amps strapped..amps are stable @ 1ohm.. What is the best way to wire my subs so I can get the most power out of them... The box I'm using is a custom built box tuned to 32hz.. If possible...
