Low hz rumble though sub only while stereo is on
Low hz rumble though sub only while stereo is on i have 2 0awg power and 2 0awg grounds plus aditional grounds connecting bed and cab of truck to frame. seems like a ground loop but i cant find it. i have a skar zvx15d.2 v.3 and a RP2000D
Where are your signal cables running? Are they near the power cables? If it is an aftermarket head unit... is it grounded well?
Power remote and v meter wires down driver's side And high end 6ch shielded coaxial bundle down pass side. The ground For the stereo is factory ground
Hmmm, hard to say. If it is "humming" at idle, no music playing... I would start physically touching cables and wires with your bare hand. Many times a suspect cable will either silence or amplify the hum. Then you can trace that wire or cable and correct the connection usually. Just a suggestion. It may or may not yield a result.
It's not Humming it sounds exactly like my exhaust Its weird
krystofir2009
krystofir2009
U.S.A.
shredder2
