Jacob Pierznik
CarAudio.com Newbie
Hello, I have a 2007 Honda accord exl 4cyl with a sound system I've always had trouble with and I'm stumped as to what the issue is. I have a kenwood dmx809s, a skar 800i.d amp and a brand new skar svx10d2 wired to 1 ohm for 800watts, I also have the big 3 kit as well. I've had this low subwoofer output issue for a long time and always thought it was the android headunit I used to have so I changed it, but even after that I'm having issues still. Im having a voltage drop issue and I even re did the ground today since the shop that originally did it just used a self tap screw. I even tested the location with a multimeter and used a nut and bolt but still no luck. At high volume I drop from 14.3 to like 12.8 volts at the amp, but it doesn't make any sense to me being that the car has a 130 amp alternator and I only have an 800watt amp that I'm having voltage drop. Any help with this issue is greatly appreciated
