Painting my sub box
  • 5
Rayher12
So I want to paint my sub box. I know that mdf absorbs paint so I know I have to put a layer between the paint and the wood. I was wondering if I should get wood sealant or a primer paint? If I should get a wood sealant can it be any kind?
I use sanding sealer. Two coats works good.
If you paint mdf use a shellac base primer like BIN to seal the wood. Without using a primer you will need a good 5-6 coats of topcoat or even more depending on color and product you are using and if you try to use something with a high sheen it will dull because of the paint soaking into the mdf.
MDF is literally sawdust and glue pressed together with a lot of force. Its very porous and must be sealed.
Sanding sealer is for wood that will be clear coated with no additional stain or coloring step. I wouldnt use it on mdf.
Will the mdf swell since it’s water based?
Will it swell because it’s water based?
I’m pretty sure it’s oil based.
Kilz original is oil based that will work.
Kilz 2 is water based which you don't use on bare wood
Shellac based primers have the best binding and sealing properties on a wide range of surfaces.
Oil based primers stick well on wood and metal and can seal well too.
If you use a dark topcoat it's a good idea to tint the primer.
If I recall, there ae quire a few made just for the tesla Y, all the tesla s for that matter...
108
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
517
Rayher12
Rayher12
Fresno, Ca
THATpurpleKUSH
    Apr 28, 2024
    Apr 28, 2024
