What should my voltage be when my car is running...
  • 6
Depends. my 2005 Ford is pcm regulated, so I depends on the temperature outside. I usually get around 13.8 when its 80-90 degrees. I only had 13.2 in NC last week end at the sundown audio show
12.7 today at 95 degrees. I live in Tampa so ac is a must
Well I guess I will order the alternator
Also my voltage meter is hooked up to the amp should I be testing the battery voltage directly or is the amp ok?
Break out the multi meter.
If your fuse is blown to your rear battery and your volt meter is hooked to your amp you are only going to be reading rear battery voltage. Hook the multimeter up to the alternator post and read voltage.
Apparently I am supposed to calibrate this little soundqubed voltage meter which I didn't do so that might be a problem
The CT's are nice, That Sundown is a a frik'n beast!
531
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
484
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
571
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
893
danielbea122
CarAudio.com Exclusive
danielbea122
Tampa
danielbea122
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
