What should my voltage be when my car is running...
Depends. my 2005 Ford is pcm regulated, so I depends on the temperature outside. I usually get around 13.8 when its 80-90 degrees. I only had 13.2 in NC last week end at the sundown audio show
Well I guess I will order the alternator
Also my voltage meter is hooked up to the amp should I be testing the battery voltage directly or is the amp ok?
Break out the multi meter.
If your fuse is blown to your rear battery and your volt meter is hooked to your amp you are only going to be reading rear battery voltage. Hook the multimeter up to the alternator post and read voltage.
Apparently I am supposed to calibrate this little soundqubed voltage meter which I didn't do so that might be a problem
danielbea122
CarAudio.com Exclusive
danielbea122
Tampa
danielbea122
